Jandy AE-TI 2500t heat pump flow requirements
Apr 19, 2013
3
Hey. New to this but does anyone know the minimum gpm for this heat pump. I just installed a new Jandy stealth 1.5hp 2 speed pump and I want to operate it on low speed but I cannot locate the minimum safe gpm in my manual or anywhere for my heat pump. Thanks in advance for any help. :hammer:
:wave: Welcome to TFP!!!
FYI, Generally heating is more efficient at higher flow rates.
There should be a low flow switch in the heater, you could simply try it on low and see if it operates ... likely it will, but will not transmit as much heat to the pool.
