Thread: Hayward Pump/Filter New- Backwash problem
    May 2008
    Webb City Missouri
    28
    I have finally got my pump and filter up and running, but when I turn it on filter, some backwash water comes out. I took the top off and checked the big O ring and it is in place. why would I have water coming out the back wash on FIlter mode
    Tysnest
    18x33 AGP
    16000 gallons
    Waterford 1 1/2 HP/2speed
    Waterford High Rate Sand Filter 21 inch tank
    SunGrabber Solar Panels 3 2x20 ft panels
    New at this pool and clueless
    If you have a multi-position rotary main valve then it is probably a problem with your spider gasket (inside the rotary valve).
    May 2008
    Webb City Missouri
    28
    Thanks for your response. That is what the pool place said to, but be "clueless" on that, I decided to turn it to backwash for a few seconds and that did it. There must have just been some water in there that was coming out, but once I did a backwash the problem stopped.
    Tysnest
    18x33 AGP
    16000 gallons
