I am trying to decide which easy touch model I need. I have a connected pool and spa with a single pentair variable speed pump. There are three valves for the each of the skimmers and the main drain. There is another valve for the spilt of the spa drain and pool. Then there is a valve to split the pool and spa returns. That makes five valves in total. I have pentair mastertemp heater and an intellichlor SWG. I am also wanting to add solar at some point.
I also have 2 switches for the pool and spa lights. The pump is controlled via an intermatic timer. There is another intermatic timer for the cleaner as well. I am trying to figure out if I need 4 relay or 8 relay version.
