Hi all,
I'm a bit torn an what to do here, so some feedback and recommendations would be much appreciated.
We initially decided on Jandy aqualink PDA, but now I'm a bit torn maybe getting the I-aqualink model. The builder is telling me either system is nice (I-aqualink will be more expensive), but PDA has more options and also that I won't be able to add on or switch to I-aqualink once I decide to go with PDA system and or vice versa.
From what I understand now and please correct me if I'm wrong:
Aqualink PDA is part of the aqualink RS system?
I-aqualink is separate model and is not compatible with RS systems?
I can add other jandy equipment to the RS system in the future (salt system, booster pumps, actuators, etc) with pretty much plug and play effort?
Aqualink touch, PDA, all button, all use the same power center RS?
Aqualink power center RS (that i will be getting as part of the aqualink PDA system) includes all electronics to be able to add aquapure salt cells in the future without having to get another power center?
Aqualink RS is compatible with nature2 combo unit and aquapure salt system but is NOT compatible with aquapure Ei system?
Thank you all very much for the feedback!
Sent from my iPad using Tapawhat?
