- Jun 12, 2011
- 3,767
- Plaster
- Pureline Crystal Pure 60,000
Do I have a problem?
Most here seems to have pressures at the filter around the 15-20 psi range. Some even in the single digits. My pump pressure is usually around 30 psi. I do have an in-floor cleaning system and solar heating. The solar collectors are about 50 ft away and 1 1/2 stories above the pool, so that adds some resistance and 7 or 8 pounds of head pressure. As the cleaning system cycles through he zones, the pressure fluctuates by about 5 pounds, but seems to run in the 28-33 psi range.
Is this a problem?
Is this a problem?
