I have been here awhile, learning and asking questions. Here is what I know at this point!
20000 gallon inground gunite pool with spa and water fall( Can run spa or water fall but not both at the same time)
4 pumps
1.5 hp pentair whisperflow main pump Now is dead!
2...1.0 hp pentair whisperflow pump used for resistance swimming
1.0 hp penatair pump for spa/water fall or a booster pump?
gas heater
solar system single story house have not been up there yet( waiting on service due to a end cap that blew off).
Polaris EOS command center( believe it is not a mechanical timer)
Have a home warranty and have contacted them for service
They should call shortly?
the question is Should I consider a lower HP motor 2speed vs a variable speed motor depending on the outcome of the warranty
It seems to me that I can intall the wirring if everything matches up to the old pumps.
Pool guy is quoting 1400 to 1600 for replacement
Seems as there are better options out there.
Any and all comments are welcomed, I just think from reading and learning, that i should go with a 2 speed pump.
Might consider a 1 hp 2 speed vs a variable speed
I think the pumps were over built originally.
Thanks in advance
Soon to be my own pool boy
Dirtfrmr aka a golfer who is always in the dirt
thanks again
4 pumps
gas heater
Thanks in advance
thanks again
