Feed back desired.
pool Spec
Free form
size 21 x 32
depth 3.5' - 4.5' - 6'
Surface area 423 sq ft
Perimeter 92'
Drains 2 anti vertex
Spa
Size 37 sq ft bi-level bench
spa height 18"
Spillway Multi tier
Blower 2HP
Fountain line included
Drains 2 anti-vertex
Equipment
Pump Pentair intelliflow 3050 vs = svrs
Filter 60 sq ft pwntair DE filter
heater 400k BTU Pentair (NG)
Booster Pump No
Sanitation RB320 Automatic Chlorinator
Cleaner Polaris 280 with 0.75 hp booster pump
lights (1) 500W (1) 60W
Check valve o
Automation Pentair Wireless 4 pool Controller
Plaster Pebble Sheen
Coping Oklahoma, Café'
Benches 2
Tanning ledge Yes, 2 Gushers in tanning bed
Deck Textured Mat single color 300sq ft
Also Included
32' of stone wall on beam at 12 inches tall
11sq ft. of stone steps and veneered risers
3' of raised pool beam at 6 inches
40 ft of gas run to equipment
1 additional spa light
(3) scubbers
repair/replace/reroute sprinklers
repair/replace 4 pallets of damaged sod
1 gate to code
1 door alarm
135' 0f 60-degree rails to bring fence to code
umbrella/volleyball sleeves
concrete pad for equipment
Standard features
plans and permits
(2) skimmers
Freeze guard
pool miser automatic leveler
Pentair never lube valves
Overflow line
shotcrete gunite 6200 psi
Flood light at equipment
Choice of tile aspotters on all steps
all lines run and valved seperatly -2"
Backwash line to sewer sweeps with p-trap
tie into down spouts where needed
deck drains where needed
set of maintenance tools and Chemical test kit
personal walk through
Lifetime structural warrently
$53,957.68
Extras cost
IF dig hits rock exta $295/hr after 6 hrs
pool Spec
Free form
size 21 x 32
Perimeter 92'
Spa
spa height 18"
Spillway Multi tier
Blower 2HP
Equipment
Booster Pump No
Check valve o
Benches 2
Also Included
(3) scubbers
1 gate to code
1 door alarm
Standard features
plans and permits
(2) skimmers
Freeze guard
Overflow line
$53,957.68
Extras cost
