Thread: What water temp is required for SWG to operate?
    Pool is pretty cold. About 60F. I am going to clean the cell today, but I get the solid light for clean/inspect cell. System is Mineral Springs.
    Is there a minimum temp for proper operation?
    Thanks!
    Bill
    30,000 gallon vinyl / Starite pump, Sys 2 cartridge, Max-E-Therm 333k heater / Bioguard SWG
    ktdave's Avatar
    Katy, TX
    888
    Most SWG cells shut down around 55 degrees F. It depends on the model, check your manual or let us know what model you have and maybe we can find that info for you.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Jul 2007
    Brisbane, Australia
    874
    Mineral Springs is rebranded Goldline Aquarite.
    It turns off the production at 50 degrees
    Thank you Strannik. I did find this at the back of the 'minimal' owners manual. Need to RTFM before posting.
    Picked up Mur acid yesterday and will clean/inspect.
