I'm replacing the intake valves on my pool so they can work better with the Pro Logic automation system I am installing, and I ran into a problem. The line coming from the spa was glued to where there is only about 1/8" of pipe sticking up above the pad before you hit a fitting. It's a 2" pipe that went right into a coupler and the Jandy valve was on the other side of the coupler.
I cut the valve off right through the top of the coupler, so there is still about 1/2" of the jandy valve sleeve glued inside the top of the coupler. No amount of coaxing will separate these 2 components, so I'm trying to think of other options.
Since the valves handle 1.5" and 2" pipe, one idea I had was to glue a short stub of 1.5" pipe into the piece of the Jandy valve left in the coupler, then increase it back to 2" right afterwards. Do you think this would work, and if so would it reduce my flow too much having just a short section of 1.5" pipe? Any other ideas?
If I can't figure anything out, I'm going to have to either get out my chisel and start chipping away at the concrete, or start digging beside the pad and try to find the line underground and tap in there. Neither of these are appealing options.
