Justin's test kit is not yet in his possession but I've been following his saga. Since you just filled with new water, you are safe to assume all your parameters are ok for the next few days 'til your kit gets to you.
However, to keep your pool sanitized and algae free, I would put in one small jug of Clorox each evening until you get your kit and post the full set of numbers.
Remember to put the Clorox in after the Sun is completely off the pool (or very close) that will protect the Clorox from UV and allow it to work on any organics that may be in your pool.
You'll lose almost all of the chlorine the next day because you have no stabilizer.
However, since your water is clear you can go ahead and add the stabilizer into the skimmer (pump running) and have that starting to slowly dissolve (it'll take a few days) in your pool. Do not backwash while the CYA/stabilizer is dissolving or you'll lose it.
Use JasonLion's calculator to tell you how much stabilizer to add....shoot for 40ppm to start.
