Having trouble with the EasyTouch wiring instructions as well. The confusion seems to be that I do not have a 2 speed pump. My Question(s) for anyone that can help! I have an Intelliflo (variable flow) 3hp pentair pump and Salt Chlorine Generator. Do I wire the pump directly to a breaker, then connect the pumps communications port wire to the easy touch?...... if this is correct - how does the SCG get wired? Do I connect the SCG transformer directly to another seperate 20 AMP breaker? or hook the transformer to the Pump Relay Line-Load, if so this means the SCG is not wired to/with the pump power correct? anyway any help!!! I just want to make sure the SCG only turns on when the pump turns on etc.
