I have a 33,000 gallon black PebbleTec in ground pool, suffering from years of chronic scale or calcium build up on entire pool surface. Usually in spring I drain and manually acid wash (very labor intensive). Pool supply store clerk suggested placing 10 -15 gal of muriatic acid in it for winter and let acid do its work over time. Pump will be disconnected for winter. Does this make sense?
