- Jun 14, 2012
- 2,668
- Vinyl
- CircuPool Edge-40
Martha_D said:If anyone could answer my last 3 questions id be pretty stoked.
I'll give it a shot - but it's the blind leading the blind.
Volume of the vac isn't important - the amount of flow is important. The size of the output hose is maybe important - I would think that a 2.5" output hose would have higher potential flow than the 1 7/8" hose units. EDIT: However depending on how you adapt the plumbing to the blower (Ultra Gizzmo anyone?) the resulting hole may be more limiting than the hose - but a larger hose indicates a motor with higher flow rates - or at least I think it does.Martha_D said:1. I can get my hands on a shop vac that's 4.25hp 12 gal. My pool is 20x40 and about 7 feet deep at the main drain. Will this vac be sufficient?
Not a clue - sorry. However I would think that if you directed the input of the blower through the valves in such a way that it goes through the heater - you have a good chance of blowing out the water in it - particularly if you disconnected the output side - but I would look for more expert opinion than mine which is really just supposition and guessing on this point.Martha_D said:2. I am unsure about how to drain my heater. I don't even ever use it, but I don't know if the pool guy opened it up (or whatever) before I started maintaining the pool this year. PLUS, I cannot find any drain plugs. There are 2 pvc pipes leading into it and a connector. Next to the pipes are 2 black levers. Not sure what they are. Would unscrewing the pvc joints do it?
I would like confirmation of this also. I plan to use CLOSED while blowing my main drain from my skimmer (to avoid having to plug all the returns). I plan to use RECIRCULATE when blowing my returns from my skimmer after closing off the main drain (air locking it). I plan to use WASTE (backwash might work better/same but not sure) to empty water some excess water from the pump/filter. I plan to pull filter drain plug and pump drain plugs as well which should ensure that the remainder is drained out.Martha_D said:3. When blowing the lines, what should the multiport on the filter be set to, and to blow out the filter, do I simply change the multiport to backwash with the vac on the skimmer poolside after everything is plugged?
