tlwilson said:Does Bioguard Backup contain copper? If so, I should wait to use it until after the shocking process is done, right? I don't need stains on top of the bug problem.
tlwilson said:Thanks chem geek!
I checked the pool this evening and found only 5 backswimmers. Shocking reduced the number from the hundreds to a handful. I brushed again this evening. Everything I've read said that backsswimmers aren't affected by chlorine. Maybe it didn't kill them, but they're gone. I wonder if they went to the neighbor's pool!
y_not said:.....Apparently chlorine doesn't effect them, as they breathe air, not the oxygen in the water like a fish.
They come up for air, trap it under their wing and hairs on the body, then go back down. They will lay eggs in your pool, in the algae. Water bugs eat algae, that's their food source, some it's other, smaller aquatic bugs. Back swimmers eat water boatmen and other water bugs.
Get rid of the algae and the bugs will go away, die off and new ones that come in from nearby sources of standing water will most likely leave when they find no food source. You have to get rid of every source of algae, everywhere, pipes, chlorinators, swg cell parts, ladders, fittings, you name it.
Apparently borates will help keep them out, not sure if they don't like it or what, but it is reported to work.<snip>
According to this page, http://www.parpool-spa.com/Page/PoolCare/BioGuard_Algicide.html, Bioguard Backup is non-metallic. It says it contains carbon-14. Not sure what that is or how it will affect the water.tlwilson said:Does Bioguard Backup contain copper? If so, I should wait to use it until after the shocking process is done, right? I don't need stains on top of the bug problem.
