Hello,
I'm having trouble with my Pentair IC40 SWG. I've been searching the topics, but can't quite find solutions to my problem.
Here goes....
My SWG cell has a mfg date of 5/2011. I just cleaned it with acid solution, and had barely any buildup (almost no bubbles).
My chemistry is as follows (as measured using the tf-100 test kit):
FC 1.5 (adding bleach now a couple times a week)
TA 80
pH 76
CYA 50
Salt 3600 (measure by pool store)
CH 700+ (I live in So Cal with hard water, plus hard to discern the change from violet to blue)
On my IC40, I see the following:
Salt level LED green
Power LED green
Cell LED green
Flow LED green
I have it cranked up to 100% (for about a month), but it's not producing any chlorine.
Do I have a bad cell? Any thoughts would be appreciated.
I have a pebble tek pool, about 28K gallons.
The water is clear, some slight algae, and for what it's worth, the cell diagnostics says 60%.
Thanks
Here goes....
TA 80
pH 76
CYA 50
Power LED green
Cell LED green
Flow LED green
Thanks
