POOL DIMENSIONS:
? Size: 16'-0" X 30'-0"
? Depth: 3.5 to 6 feet to top of tile (water level is 3 inches lower)
? Approximately: 480 square feet
? Approximately: 92 perimeter feet
? Approximately: ?17,100 gallons
SPA DIMENSIONS:
? Size: 5'-0" X 7'-0" elevated 18 inches above pool level
? Depth: 3.5 feet to top of tile (water level is 3 inches lower)
? Approximately:
? Approximately: 35 square feet
? Approximately: 24 perimeter feet
?EXCAVATION: 919 gallons
? All excavation is included in this proposal.
? Haul off of excavated materials is included in this proposal.
? Removal of existing steps at kitchen door and removal of rear patio (excluding steps at living room door) is included in this proposal.
? Owner will provide access into backyard for excavation.
? Cleanup of site during and upon completion.
? No tree trimming or removal.
POOL LAYOUT AND GRADE:
? Pool layout and grade as per plan.
? All forming is included in this proposal.
? 3” gravel bed in the floor of the pool foundation.
? Seven (7) sack shotcrete structure (with fibers), 8” to 12” thick with # 4 reinforcing bars on 6” to 12” ?centers with 4 - #4 bars in bond beam and additional bars at points of stress.
? Shotcrete to have a minimum strength of 4000 p.s.i. at 28 days.
? Shotcrete typical steps and seats. Other benches and lounge areas to be determined and additional ?charges may be incurred by the homeowner.
? 6 inch band of frost-proof tile at water line and trim tile on steps & seats. (Allowance of $5 per square foot.)
? Interior finish: Wet Edge Altima or QuartzScapes tier 1 products.
? Spa as part of pool structure elevated 18” above pool with vertical stone as per plan.
? Spa will have a cascade waterfall into pool as per plan. ?POOL AND SPA EQUIPMENT:
? 2 Hayward skimmers
? 4 Recirculating inlets
? 1 A&A Water Leveler
? 1 A&A Deck Chlor complete
? 1 A&A single port unblockable channel drain (spa)
? 1 A&A double port unblockable channel drain (pool / cascade)
? 1 Polaris 280 with booster pump
? 1 Jandy DEV 60 DE Filter with 2-in-1 backwash valve (pool)
? 1 Jandy Energy Filter (cascade)
? 1 Jandy Stealth 2.0 Hp UR pump (pool) ? 1 Water Feature Pump (cascade)
? 1 Jandy LXi400 400,000 BTU Heater
? 2 AmerLite low voltage 300w, 100' cord
? 1 AmerLite low voltage 100w, 100' cord
? 1 600W transformer for the pool lights
? 1 100W transformer for the spa light
? 1 Power Center Sub Panel with breakers
? 1 Jandy PS 6 pool/ spa
? 1 AquaLink 4-button spa side switch
? 1 Custom Cascade , Extended lip, 36" (cascade)
? Umbrella sleev (location to be determined)
? Set of cleaning equipment (pole, wall brush, leaf net, and test set). ?POOL DECK, COPING, AND WALLS:?(All natural stone will exhibit variations in color, thickness, density, etc.)
? Coping: Lueders (buff) set in random lengths
? 882 square feet of pool deck topped with Textured Finish
? 32 square feet of concrete for the equipment pad
? 46 Linear feet of 3' tall iron railing on ramps
RAMP AND LANDING:
? 28 sq. ft. of wood landing at kitchen door.
? 9 lin. ft. of wood ramp from landing at kitchen door to pool deck. ?
UTILITIES:
? Electric hook-up of pool equipment and lights at pool equipment by Johnson Custom Pools. In some cases the electrical service will have to be upgraded or the distance to the pool equipment is too great and additional charges may be incurred by the homeowner.
? Gas hookup of heater at equipment pad and fresh water supply with back flow prevention device is included in this proposal. In some cases the water service will have to be upgraded or the distance to the pool equipment is too great and additional charges may be incurred by the homeowner. Propane tank and gas line to equipment pad by homeowner. ?ITEMS NOT INCLUDED:
? Landscaping and irrigation.
? Fence and gates to meet code
? Propane gas tank and gas line to equipment pad.
? Form survey if required by inspector.
? Impervious cover survey if required by City.
? Tree trimming or removal.
? Any excess material will remain the property of Johnson Custom Pools.
OPTIONS:
? Upgrade interior finish to Pebble Sheen $ 4,674
? Upgrade from a Polaris 280 to an A&A In-floor ?Max cleaning and recirculation system (includes 6- ?port valve, QuikSkim & LeafVac). $ 4,810
? Add Trident UV Sanitation system $ 875
? Add a Nature 2 Express mineral sanitizing system $ 750
? Upgrade J&J Electronics energy efficient 45 watt ?white LED lights $ 770
? Upgrade Jandy Watercolors energy efficient 50 ?watt color LED lights $ 838
? Landscape lighting allowance for 10 lights with a ?transformer and labor to install. 2,500
? Upgrade the filter pump to a Jandy E Variable ?speed pump $ 559
? Add iAqualink to control system. $ 379
? Pool cover?(incl. automatic, electric, safety cover with undertrack channel; dam wall capped with tile for automatic cover; standard fabric color; adjustable brackets for walk-on lid (same as coping material); standard keyswitch controller with water feature shut-off; automatic rain water removal pump with discharge hose.) 16881.00
? Upgrade pool cover controller to wireless. $870
? Change pool deck from textured finish to pavers. $7,205
? Add 2 ft. to width of pool (incl. resulting increase ?in pool deck area). $2,012
TOTAL PRICE:
$71,313
Seventy One Thousand Three Hundred Thirteen Dollars
SPA DIMENSIONS:
? Approximately:
RAMP AND LANDING:
UTILITIES:
OPTIONS:
TOTAL PRICE:
$71,313
