Currently shocking my pool to clear up what looks like green algae. The water is clear but it's growing on the walls, especially around the light and ladder. I have brought the water up to shock levels and brushed the pool walls and floor. I am going to perform an OFCLT tonight. My SWG is currently turned off, at what point do I turn it back on? Tomorrow after I take my OFCLT readings? Do I need to remove the ladder and clean it and also pull out the light and clean in the nook behind it?
Also, for those of you with SWGs, what % do you keep your SWG at? I had it at 60% but my FC is only 3 and my target is 5-6 per the chart. I guess I'll bump it up to 80 but does this seem high? My salt is fine (3620) and my CYA is roughly 85, the SWG is brand spanking new and my 1 hp pump is running 13 hours a day. Below are the readings before shocking. Any help is greatly appreciated...
FC - 3
CC - 0.5
TC - 3.5
Ph - 7.6
TA - 90
CH - 130
CYA - 85
Salt - 3620
FC - 3
CC - 0.5
TC - 3.5
Ph - 7.6
TA - 90
CH - 130
CYA - 85
Salt - 3620
