No, this is not normal and might be a sign you have algae.linen said:If you can smell the chlorine and it bothers your skin, most likely it is CC. CC reading higher than 0.5 ppm means you need to do the shocking process.
What is your CC level?
lka674 said:Quick question though...the bleach caused this soapy bubble reaction from my spa's spillway when it hit the pool water...is that normal with bleach?
Urgh!!! Frustrating! Hence the reason why I'm learning all of this myself.....time to take matters into my own hands!
My test kit does not test CC, I'm leaving shortly to go pick up one that does. Will test and see where we are, start the shocking process if necessary and will perform an OCLT.
We DID have some visible algae about 2 weeks ago and my husband had our pool service add an algaecide, which did eliminate what we were seeing on the walls and the slight greenish hue. Since adding that, the pool "looks" really good....I would even say crystal clear....even though our other numbers seem to be jacked up.
Back later with results. Would you recommend the bleach OVER liquid chlorine in ALL circumstances? I have either AND I also have Cal-Hypo 73% and Potassium Peroxymonosulfate oxidizing shock.....long story, but after a large group of swimmers last weekend our pool looked worse than it EVER has and really cloudy so hubby was "advised" to use BOTH of those powder shocks (likely an upsale for them)...did make the pool look great, but what our pool chemistry has been maintained at for the last 2 years STILL isn't accurate....point is....I've got shock product covered for whatever ya'll think is best for the process.
