I am trying to set expectations with our new pool. How often do you all add bleach to maintain proper CL levels? From reading posts, it seems like this is a daily or at least every-other-day process, which is not a big deal of course. Also, I am more curious about this as it relates to the summer months. I am in Houston, TX, pool specs are in my sig.
Also how often do you perform TF-100 (or similar) tests? Do you only use a TF-100-style kit for testing or do you supplement that with strips and then perform a TF-100 test if the strip results look suspect?
With a new pool, I want to make sure I do everything possible to prevent problems that are within my control. If that means daily testing and adding bleach daily (among other things), then that's what I'll do.
Thanks in advance for the info!
