- Jul 1, 2011
- 44
I just installed my first pool. When I fired up the Jandy Aquapure ei I got a no flow message. I flipped my 1 hp pump from low to high and immediately the generator started to work. I am guessing the flow rate at the SWG is too low to run on low speed. Do I have any options other than running the pump on high all the time? Could this be a plumbing issue as there is a 90 about 10 inches before the SWG but I am pretty sure this meets manufacturer recommendations. Any ideas? Thank you
