Ph is 7.2 and I am currently aerating to bring it up
FC is 9.5
CC is 0
Adding more bleach to stay at shock level.
FC is 9.5
CC is 0
Why not leave it there and let it rise on it's own. Aerating will cool the pool water down. It's too early in the season for us Pennsylvania boys to be cooling the water. :lol: When your PH rises to 7.8, just knock it back down to 7.2 and let it rise on it's own again. This will lower your TA eventually. Your TA is not high.doublewide6 said:Ph is 7.2 and I am currently aerating to bring it up
FC is 9.5
CC is 0
Not necessary but it should be on about 30-60 minutes before you test in the morning.Should the pump run all night for the OCLT?
Somewhere from 40-60% is typical when getting full sun for most of the day.doublewide6 said:How much FC should a pool in full sun lose per day?
linen said:Somewhere from 40-60% is typical when getting full sun for most of the day.doublewide6 said:How much FC should a pool in full sun lose per day?
Until you pass the OCLT, you need to keep the FC level at or slightly above your shock level.
