Ok, so I will let you know what I've done and where I stand so far. This is my first year with a SWG. I went with a Compu-Pool CPSC 36. I have a 33' round x 54" deep pool. B I also put in a new two speed pump this year. I started off with liquid chlorine, algae block, and muriatic acid to start with before installing the SWG. Our cover blew in from the storms this year and ended up being jungle green. I wanted to get to a base to start with before adding the SWG. Anyhow, now I have the SWG installed and am very close to being clear. Still a little milky, not bad.
My numbers so far are:
Chlorine = about 2.5
pH = 7.2
Salt = 3900
Not really sure where I need to be. I thought salt couldn't be tasted until 5000 ppm? I have a slight taste of salt. Also, I have the SWG set to 80% output. I also only have it generating from 11 p.m. until 1 a.m. and then again from 4 a.m. until 6 a.m. So, a total of four hours daily. Do I need to change the output and generating times?
Like I said, I don't have much experience with SWG. I will take all of the advice you can give. Thanks!
pH = 7.2
Salt = 3900
