I've decided open my pool by myself this year after closing it myself in the fall. Couple of things: I didn't do as good of a job as I thought I did of removing all of the leaves last fall, so now the bottom is covered in leaves and algae.
Is it possible to vacuum out the pool using a trash pump and my 1.5 inch pool vacuum hose?
I've already clogged my pump up once going to wast, so if I can avoid doing that again that would be preferred. I've had little luck finding any info online regarding this, so any helpe or advice is appreciated!
