Maybe I should hang sock with CYA in the return line. I added 4 lbs last Tues or Wed and it still not registering? Water in deep end clear but not crystal clear.
Parker12 said:Finally last night my pool held FC value all nite and still holding today at noon.
Now, I still am not registering any CYA even though I added 4 lbs a week ago and have 2.5 lbs hanging in a sock by my return.
Assume that the amount you added is there. The test is +/- 10 - 15 and it is difficult to distinguish a 20ish CYA.
I think tonight I will add the additional 2.5 lbs and broadcast it and be done!!!
We do NOT recommend you broadcast CYA (acid) on your vinyl pool! Adding it via sock method is the best bet. Under normal conditions (not shocking or needing to backwash your filter), you could just add it to your filter. But, no go on this either at this time.
Now would be a good time for your to add your pool and equipment specs to your sig.
Pool water is clear and nearly crystal. ph is 7.2.
Keep an eye on the pH.
Any others words of wisdom from the pool Gods. I wouldn't have great water if it weren't for all of you on this forum. I cannot thank you enough for all your advice!!!
Can you post a pic of your pool for us?
Parker12 said:I think tonight I will add the additional 2.5 lbs and broadcast it and be done!!!
Lots of us use PhotoBucket.com & it's freeParker12 said:How do I post a pic?
