So it has been a heck of a week for me, along with the pool issues, i have house issues as well. Long story!
I pushed on the liner and it seems to want to stretch. There is alot of material there to play with. I am lowering the pool as i type with a sump pump. i will give it a try tomorrow, into the yummy water for me, luckily the low end! Thanks for the tips guys.
I am using the sump pump because my old pump has finally given way, i think. Turns on for 10 sec then shuts off, sounds like it shuts itself off or something. It makes a very slight click and trias to come on again, will not stay on for longer than 10 secounds. Power is getting past the swithch into the pump, changed swithch, same thing. The only thing i can't check is the inside of the metal wire housing going into the pump. but if i wack at it it does not make a difference.
Thanks for everything!
Joe
Joe
