Just installed a new fiberglass pool in NJ and now learning how to setup and maintain a pool as a first time pool owner. I have a 14 x 32 freeform with approx 10k-11k gals. I have a Hayward 1.5hp superpump and sand filter, Autopilot Dig 48 SWG and Heat Siphone 3.25 Heat Pump. I purchased the Autopilot on what forums users on the net seems to like and for the info Poolsean shared. In setting up the pool I made the error of not balancing the pool prior to adding salt. Secondly was told my pool was approx 13K gal so overshot the amount of salt necessary. Now I was in trouble. I was able to speak with Autopilots poolsean and he delivered amazing customer service. I am currently following his advice to get me back on the right track. Being a first time pool owner is a big learning curve but poolsean and others in these forums sure help to simplify the process. Its a good feeling to know we can go to places like this forum and help each other with what has worked and what hasnt. Make sure you balance your pool prior to running your SWG. Also if your not sure of your pool gallons scale back your salt input...you can always add more. Thanks poolsean and to the others here and look forward to sharing any information that I learn here on TFP.
