- Mar 22, 2012
- 34
I am going to attempt to install my first above ground pool this weekend, it is a 24' sharkline venture. One of my several questions is my pool is going to be approx. 25 feet from my garage. I have a new Hayward 1HP pump and sand filter. Is it possible to bury the intake and return lines back to my garage and set the pump and filter against the garage. I was planning on using schedule 40 rigid pipe. I think it will clean up the look of the pool not having them setting next to the pool. I just wonder if the pump will have enough pressure to pull water back and forth from the pool. Any thoughts?
