I have a 15x30above ground. I have a question about pool heaters. Im looking to get a rheem above ground pool heater. Is rheem anygood? The other problem is if i put the heater near my house ill have to run the pvc pipe the length of the pool. My return and basket are on the other side of the pool not near the house. Will my pump be able to move the water good enough. i just dont want to spend a lot of money on pipe to run the gas line if i dont have to. Ill take any advice on what kind and brand of heater to buy also. Thank you
