Just to give some context to my rant before it gets out of hand. It was not intended as an arbitrary DE bashing, nor as a forum for the yearly debate on filter types. Fun as that may be!
It was and remains simply a rant.
I waited too long to get things going this Spring, and let the pool go green. My bad.
This is an important point in my annoyance with my filter, expressed in this thread.
You see, my normal method is to thoroughly backwash after the Fall deluge & clean up so that the filter will be ready for Spring, because there is the known Spring deluge & clean up...after which, another backwash is required! The green pool threw a monkey wrench into my plans, because the Spring deluge is not finished yet.
So here is my quandary which prompted Sunday's outburst: 1.) The filter needs to be backwashed because it just cleaned up a green pool. However, 2.) the Spring deluge is not finished, so typically I would backwash again before Summer swimming. 3.) The weather is unseasonably warm, so the pool requires chlorine, which also means it needs CYA!!!
You see where I'm going with this. I need to add CYA which is not super cheap, after which I am going to have to turn right around and flush a good portion of it down the drain, not once, but most likely TWICE! Very annoying... And it doesn't help that I really don't care much for handling DE to start with.
So some of you are right: My rant is certainly biased against DE & toward cart. Others of you may be right by suggesting I'm making my own problems by insisting on backwashing instead of breakdown/cleaning. Did I mention I don't care for handling DE? IMO it is nasty shizzz that has its proper place down a drain.
And lastly, as I stated at the very top of the thread, if I wasn't flat broke, I wouldn't think twice about throwing CYA willy nilly all around the pool. Again, my bad.
But it annoys a brutha don't you see?
:blah:
