- May 3, 2007
- 16,895
- Plaster
- Hayward Aqua Rite (T-15)
The heat gain for any solar panel is governed more by the angle of incidence, area of capture, and the panel efficiency. Based on independent efficiency measurements (see the link in my sig), those panels are not much better than the average panel.MattM said:My wife says the solar guys stated that the heliocool panels were not as direction sensitive as most panels, and that we would want to save the good roof space for solar electric later.
Anyway, assuming you have a few more days like yesterday, you should be able to maintain 75 degrees with just solar. But that assumes your cover prevents evaporation and some heat loss. Those covers look to be in the water and if mesh, then they probably don't hold the heat very well. So using just solar but without a cover would be around 69 degrees. BTW, about how much heat do you lose overnight? This can tell you how well your cover is holding in the heat.
