- Mar 4, 2008
- 10
RE: Autopilot Digital 36 In Use 5.5 Years, Replace With
First I have to thank everyone that was trying to help me with my Autopilot troubles. Next please let this thread continue as the help I am getting is needed and much appreciated.
I have to say Autopilot does take care of their customers. Sean showed up at my home today to check out my system. What he found was a burned connection in the Black Banana Plug. I went to radio shack and got some new Banana plugs. I replaced both the black and red. The red looked a little rough but appeared to still have a good connection. I powered up and my cell is working. I feel kind of dumb. Every other time a cell died it gave the same readout as it did for the burnt connector. So I just figured it was another cell. This is great because not only is my cell working but It means this cell has lasted longer than 2 years and seems to be going strong. Thank you so much Sean!
Waterbear, I am getting my levels to where you suggest. We had a big rain last couple days so I have added some stabilizer and salt. Right now CY is sitting at 90. PH is still 7.4, TA 90, calcium 260, salt 3400, chlorine 1.0 maybe a little higher and the settings are level 2 , 20%
Can you give me a list of what you would consider the perfect chem evels I should be running at?
You had mentioned running the Digi 36 at level 1 and changing the %, what do you recommend?
Thanks for the Help.
