Our Jacuzzi J350 is about 8 years old, is under truss on the patio & has a spa cover. The last couple of days when we checked it we have found it off & the circuit breaker tripped. When I reset the breaker the dreaded OH error code is shown. When I shut the breaker off & on again then the display is normal. I have seen the temp gauge go downward reading the current temp but a it may immediately shoot up to 112-114 then pop the breaker. (Of course the water can´t be that hot with the power off for a day. ) Upon reset OH is shown once again.
I can turn on the Jacuzzi & it will power on the pumps, lights, heater, etc. but it has to be just after resetting the breaker, usually twice.
It has gone through 2 of the 20 minute cycles but will trip the breaker again.
We did a drain & fill 4 weeks ago but haven´t used it in 2 weeks & at that time it was working great.
Can somebody tell me what to look for in regards to the OH error.
I pulled the side panels off & don´t see any leaks, the floor around it isn´t wet, etc.
I did see that the ozonator indicator is off. Could my problem be caused by the ozonator?
Thanks for any help and suggestions,
