just finally got levels under control after a couple weeks. (after an overfill/spill of water)
For several days now PH is 7.5, simple chlorine test showing 2. With the detailed chlorine test from TF-100 showing 3.5 fc + .5 CC Pool is saltwater.
Hoping the .5 is ok so we finally can get a couple weeks in swimming before summer ends?? I know it's right at the limit. If not okay, I guess the "shocking" procedure in poolschool would be needed....how long does that take usually, before you can get in and swim again?
