Thread: How often/long do you run your Cleaner?
    Martin2003's Avatar
    Sep 2007
    Richmond, TX
    17
    I'm curious how often (days/week) and long (hrs/day) do you run your Cleaner? Also does it change between the winter and summer seasons if you don't close your pool?
    I currently have mine set at 3 hrs/day 7 days/wk which seems too frequent to me.
    Thanks
    Torben
    22,500 gallons IG gunite free form w/ spa, Tropical Breeze Pebbletec, Intelliflo Variable Speed, 2hp Whisperflo for waterfall feature, Intellitouch, Quad DE 80 Filter, Mastertemp heater, SWCG
    iggy's Avatar
    Jan 2008
    The Cool Part of Arizona
    175
    Re: How often/long do you run your Cleaner?
    Quote Originally Posted by Martin2003
    Thanks
    Hi Martin2003
    I just answered someone here that I was just running mine about 4 hrs a day, 7 days a week.
    It also depends on how many gallon pool you have as well as how well your pump pumps.
    I figure my pump can pump 100 gpm which is 6000 gallons an hour and fow 4 hrs = 24,000 gallons total
    24,000 gallons is about twice my pool has in it. I figure two total exchanges each day.
    I may consider changing my timer so I can pump every other day instead of daily during the winter.
    That should help reduce the electric costs and still maintain good water.
    Iggy
    In-Ground SWG pool 11,000 gal., Jandy CL460 Filter, 1.5hp Stealth Jandy pump, Paramount PV3 In-Floor cleaning sys., Goldline SWG, Hayward Color Logic 2.5 LED Light
    ktdave's Avatar
    Katy, TX
    888
    Another consideration is how much debris is getting into your pool. I have no trees to worry about, just the "junk" such as dead grass , bird poop, dog hair, etc. and I have found that running my cleaner for only 1 hour (small 11,000 gal pool) per day is sufficient.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Feb 2008
    45
    It varies from pool to pool, as well as with different cleaners. Play with it a bit. If you run it an hour a day and your pool gets dirty, run it longer. It's really going to be trial and error to find just the right duration.
