First reliable test
MK1985
68
Barron Wisconsin
I messed up my first test I did back on the 19th, it was getting dark and the results were not right. But the ph test was easy and it was over 8 and I hadn't put any cya into the pool so it was 0. Anyway I added stabilizer/conditioner and dry acid to get the ph down. I took a test tonight and took my time, here are the results.
FC 8
CC .5
TC 8.5
ph 7.2
T/A 110
CH 270
CYA 40
The water is crystal clear and feels smooth when swimming, going by the test what is my next step?
See how it works out 1st. The Intex SWG seems to be able to maintain FC just fine at slightly lower CYA levels. If you find your FC dropping day after day, you can increase it to 60-70 in a few days.
