I have a new pool, noticed that the pressure hasn't been holding. The pool isn't finished yet, so all plumbing is capped and plumbing is pressurized. It drops about 5 pounds of pressure within a day or so. I noticed that the skimmer has two valves, the one closer to the pump lets out an small air bubble every 30 seconds or so. It's a tiny bubble, the pressure reading is 30 psi.
the plumber says this is normal, everyone else I talk to says otherwise. What's your take on this? is it an issue? does pressure stay still for a day?
i also notice that water seeps out of the skimmer to the pool wall, not sure if the air bubble has anything to do with that,
tomorrow they are planning on pouring the decking and I have thrown a fit about this, if you can give me some answer quickly that would be appreciated,
thank you
thank you
