So I opened my pool the same way I did last year. As of right now my water is crystal clear, smells like a pool, looks like a pool, feels like a pool etc. and has maintained this way for several days now. However when doing my testing I came across a scenario I have not before. My TC tested at 0. So I went and tested my CYA to see where I was at with that and this also tested at 0 several times(I could see the dot after filling up the whole vial clearly)
PH=7.5
TA=110
Both in the norm.
Is the simple solution just to put in some Stabilizer to raise my cya level which in turn would help retain chlorine levels?
PH=7.5
TA=110
Both in the norm.
