Opened the pool on Tuesday. Have been running the pumps 24 hours/day since then. I brushed the walled yesterday and made a huge mess, but today the water is clearing up and the bottom needs to be vacuumed still. Tonight I ran my first set of tests. Here are the results.
FC - 7.5
CC- 0.5
TC - 8.0
pH - 7.2
T/A - 110
CYA - 30
I'm glad the CYA has come down over the winter. I had some water loss that turned out to be cause (hopefully) by a bad seal on the light. Its been holding water fine since Tuesday. Last summer my CYA was very high ~100. It will be nice not to use as much chlorine. Any thoughts/suggestions on my test results. Looking forward to getting things stabilized and cleaned up. New solar cover this year that needs to get cut and put on and hopefully raise the water temperature a little.
FC - 7.5
CC- 0.5
TC - 8.0
pH - 7.2
T/A - 110
CYA - 30
