I am pulling the permit shortly. I plan to do much of it myself, but am going to work with a hot tub technician that does 5-6 pools/year. Just need to wait till some of his former clients open their pools so I can check his work.
I would like to use this thread to ask questions as they come up. Hope you gurus out there can help.
Here are the basics. It will be roughly 20x40' with a diving end (8') and 3.5' shallow end. I want the ability to add solar. I plan on using a pentair system including the intelichlor/easy touch, intelliflo and the largest or 2nd largest cartridge filter available. One, possibly 2 LED lights. a few deck jets placed in shrubbary (perhaps). I would like to do an overflow spa, but somehow a seperate hot tub down the road seems easier. If we don't do the overflow, i will do a bumpout with jets or at minimum, have jets at the stairs so I can sit in the path of the heated returns.
There is a pool manufacturer 1 hr away that is highly regarded: Highbury pools, so I will likely go with them since the builder is farmiliar with their kits.
I'll start by asking about tigerflex flexible pool and spa hose. The builder says it is all he uses and he only has ever used 1.5". From my reading, I find most suggest 2" plumbing. I also read a lot of negative comments from southern states where termites like the taste of tigerflex. It appears that in northern states and canada, tigerflex is a usual product as it will handle freezing and ground heaving from frost...
