Re: Pool light screw stuck...what can I use to get it turnin
I went and bought the Impact Screw Driver set. $7.00 at Harbor Freight. It worked to break the screw, but not enough to really loosen it. I had to wack on it for some time. When I took a regular Phillips head to see if it was loose, I was able to get just a bit of movement, tighten only. The head was pretty messed up by this time. I hammered a Phillips screw driver into the head and was able to get enough bite to finally get it out. I had to hammer the screw driver into the head several times as the bite wouldn't hold for much of a turn. It took me over an hour to finally get it out. I was lucky not to break the screw tab. That is certainly a possibility.
