Does anybody run a solar heater and not a blanket. My solar blanket is a pain to get on and off (above ground pool and I have to lift off reel), and I don't really have a place to put it. We actually only use it for about a month, and the rest of the summer we have more issue cooling the pool off. So I noticed that we can get a solar heater for fairly cheap and was wondering if it will heat the water enough to compensate the overnight heat loss, and still warm the pool enough to swim in. Also, if we have the panels at the same level as pump do we need a supplementary pump for the solar heater?
