This is the model of Intermatic Timer the PB installed:
Model - T104R3
Description - Time switch in metal enclosure
Switch - DPST
Clock Supply Volts 60 Hz - 208-277
It appears to call for 230 vac.
Here's a picture of the timer wiring itself and the wiring diagram:
Here's a pic of the pump, timer & IC 40:
Is it possible I'm already wired for 230? I have a multitester VOM. Where would be a good place to check the voltage to see what's there?
Model - T104R3
Switch - DPST
