Hi ,
Ive just conected the ST to the VF and arfter 3 days and rereading the instructions a few times Ive got it mostly worked out . MY pool is 22ft by 7 ft and 4000gal I have solar with 3way valve and actuator , thats it simple .
On the Suntouch I programed FLOWS pool 25gpm and 2nd Flow Solar 30 gpm but when the solar is running and I check status it says 25gpm .
The real problems is Iam just guessing (educated ) at what Iam supposed to enable or set , I assigned a circuit for the pool and then another for the solar in the pump section .
The other thing is scheduling 4/14 I set the pool to start at 630am and turn off at 530pm , it turn on ok but switched off at 5pm .
Does anyone have any hints , like should it be set to single body or shared equipment , its in shared equipment now as the pump would nt turn back on arfter the solar turned off .
I did get a intellicomm II with it but the ST has had the firmware up grade to support the VF I thought , but I now thinking maybe useing an ext control on the VF would be easier and I keep the us of the keypad on the pump !! .
Iam sure they sent the instruction to russia translated to russian the to china into cantonese then back to America to to american
thanks Dave
thanks Dave
