Hello! I am a 27 year old pool service tech. I have been in the business for 5 years now. I'm pretty familiar with all the pool equipments except the Jandy AquaLinks with the built in AquaPure. I need some help resolving a problem I have encountered with a customers system.Â
I got a call from my customer on Tuesday telling me that her equipment was turning on and off at random times. I went and and noticed the main panel would turn off and all the LED's would go on and off chasing each other. I couldn't take it out of Auto Mode. I hit the reset and flipped the circuit breaker on and off with out any success. I disconnected the spa side switch black plug from the main board in hopes the switch had gone bad. Still no success. I assume the board is bad.Â
Here is my question.Â
The customer has a rental home with the (I think) the same unit hooked up to a spa only. She has requested for me to pull the board off of the rental home spa and install it on her primary home that has a pool and spa combo. Is this possible? If so, does the programming remain the same or must I remove sone type of memory chips from the boards too?
Please help!! Thank You!!
