I'm having issues where I've had a ton of turbulence in my pump strainer basket. When I was still using a pool service he mentioned that this was normal for this type of pump. I've been messing around with it and I notice that when I divert water away from the skimmers and to the main drain the turbulence in the pump decreases greatly. At the advice of another thread someone mentioned the weirs may be the culprit. I've looked at my weirs and I've even held them down yet the pump still has a ton of turbulence unless I close off the skimmers. Any thoughts?
