Using the test kit by PB gave me; here is everything I could test this am:
FC 2-3
PH 7.8
TA 40
CYA 70
Water temp: 89
Daytime temp yesterday was 103.
I tested yesterday and the PH was off the chart, I added a quart of acid and rested a few hours later and added another 2 cups. These are the numbers from this morning. From the suggestion of the acid-demand test, I added another 2 cups of acid before leaving for work. My PB said that the pool would require a good bit of acid the first month.
The FC took a good dip between the am reading and the 6pm reading. I was 3+ yesterday am and around 1 at 6pm.
Should my FC and TA be higher?
Pool is a new IG gunite, 21k.
FC 2-3
PH 7.8
TA 40
CYA 70
Water temp: 89
