Morning Numbers:
FC: 10.5
CC: 0.5 (best I can tell)
PH: 7.5
Still having a little difficulty with the drop test. Added the 5 drops to check for CC and it appeared to slightly change from clear - so added 1 drop then another of the first reagent - it did seem to turn back to more clear - but couldn't tell difference in adding one drop or 2. It didn't really turn 'pink' with the 5 drops, just seemed to add a little color to it.
Visible - not much left to be seen. The normal crevices where I find grass, sand, debris had a small amount - but when I brushed it I didn't see any of the cloud puffs, so I think it's just sand/dirt. I'll try to vacuum it up tonight and look for it again tomorrow.
I plan to continue to let the Free Chlorine burn off to around 4 and try to keep it there. Will verify CYA once again in sunlight and use Pool Calulator for FC levels. If under 30, I'll probably use some Tri-Chlor pucks for a few days to try to bring it up a bit. Taking sample to pool store today at lunch and buying 45lb. bucket Proteam Supreme Plus - Any comments on that? It IS proven to be safe and effective - right? I will post the results from pool store - I want them to check for borates just in case someone had already added them in a previous incarnation of the restored pool.
Thanks and let me know what I'm missing. The one thing I'm not sure is how much I should raise Cyanuric Acid level. I actually bought a 5 lb jug at Home Depot but thought I'd return it and get something smaller (that was all they had), or just use the pucks I already have for a week or two. But being in full sun all day maybe it needs to be well above 30?
