I just replaced my 1 month old liner and I have it full againas of yesterday. Last start up I shocked right away and turned the pool orange from metals and got a few stains from that. So my question is to avoid any more stains to my skimmer and ladder should I do the metal out first and then chlorine,ph,stabilizer? Or can I do the chlorine and metal out all at once? I haven't added anything yet, just wanted to see what order to start. I used well water to fill it. Last results before anything was added (pool store results) were:
Total Chlorine .01
Free chlorine .01
pH 8.2
TA 160
CYA 10
I will be using bleach for chlorine and shock,I have a gallon of muratic acid and I will need to get some metal out and stabilizer. Last start I used 2 1/2 32 oz.bottles of stabilizer and my CYA was running about 40 so I will probably do the same with that.
I pretty much know how much of each I will need I just need to know in what order to do it all in. Thanks so much !!!
Total Chlorine .01
Free chlorine .01
pH 8.2
TA 160
CYA 10
