Help!
I have very clear water but the pool water looks green instead of blue.
We had the water tested and fixed ph, etc. and have been shocking it, putting in algaecide, brushing, backwashing, you name it and it looks green anyway.
The man at the pool center gave us a lot of alkalinity up and it seems like it has been doing this since then. It's right where it should be and ph is about 7.2, on the low side. However, it says on the shock that it should be in that range if you are fighting algae.
Does anybody know what I should do? I am having a party Labor Day weekend and am getting nervous that I won't be able to fix it.
Thanks
Thanks
