For the TA, keep adding drops until the color stops changing. Usually the solution will be pinky-red to red-red. When you add a drop and the color does not change you are done. Subtract the last drop and multiply by 10 to get the TA result.
For FC the same principal applies. Add drops until there is no change and subtract the last drop before computing the result.
The FC may pinken again after a few seconds if you let it sit, but you can ignore that. Hold a piece of white paper behind the vial to help tell when it is clear.
